frankymusik
Flight distance : 27841053 ft
... if you use the DJI Assistant 2, you can see under the menu item "Log Export" how many flights are saved internally...
For the Air 2, it's the last 10 you see there. All older ones will be overwritten automatically...
With newer DJI drones, there is much more data that is stored internally!
If you now switch the Air 2 on and off ten times in a row, these 10 data records only contain the last switch on/off processes, so all original flight data have been "deleted" (correct: overwritten)...
In the event of problems (guarantee claims, repair requests, etc. pp.), DJI asks you to upload the relevant data set (sorted by date and time) and transfer it to DJI...
You have access to these flight data via DJI Assistant 2...
However, if the event in question was overwritten (by repeatedly switching it on and off), then this data is (unfortunately) lost...
