Tuxtard
Flight distance : 9975610 ft
Serbia
djiuser_TC0LPWGbWc7g Posted at 2-26 03:09
but why do those cameras produce so much grain? i feel cheated because i did so muich research, and not a single "reviewer" spoke of this. do higher end models do this as well? is there no way to prevent it aside from editing ?
messing with iso and shutter doesnt do anything... As far as I know, higher end models don't have this problem. There is another thread where user is experiencing similar problems with DM2 that are not present on his MA2 - https://forum.dji.com/thread-229115-1-1.html
DM2 is not advertised as a professional, but entry level device. Reviewers probably have that in mind when they are testing it. On the other hand, many people are not bothered with the noise level that DM2 produces, or they are using too small screens to even notice. I was disappointed with the level of noise, flicker and compression artifacts that MM1 produces, but still got DM2, even when I knew that it has the same camera and sensor that MM1 has. I got it because of the other factors, like weight, size and portability. |
