apuzer
Good Day,
When flying an inspection mission on solar site, when flight is heading of 0 or 180 degrees, the camera images follow the rows left to right or right to left. When flying 90 or 270 degrees, the rows facing up and down on the screen. My camera is pointed straight down (csometimes pan is adjusted for glare). My custom camera is set up for the rows to be left to right. I am having to manually set the camera direction at the start of the mission, and then keep an eye on things during flight.
Secondly, is there a way to adjust the standard H20T camera settings for Zoom? I currently have custom cameras set up for thermal and wide, for am mapping sites. Due to the shutter on the H20T much more overlap needed to get a decent orthomosaic. It does not seem that I can select 2 custom cameras at the same time, although one is Zoom and one is Thermal. I can select the images saved...zoom and thermal--however the stock zoom does not give me the overlap or a low enough timed interval to be effective...unless I fly very slowly.
Any advice from the field greatly appreciated.
