John-_-D
fans7d933bff Posted at 3-14 14:59
The thing is you have to hold it down for three seconds... which is pretty unsafe as holding it down means throttle down.. isn’t there a switch that just kills the motor immediately?
tomekyo's advice is right, so I'm puzzled what is concerning you. Pulling the stick all the way down doesn't actually turn the engine off in mid-air, it just says "descend". As the drone gets close to the ground, the sensors are aware of the approaching surface and slow your descent so it lands gently. When you keep pulling down on the stick while the drone knows you're on the ground, that's when the drone will shut off the motors. It won't happen in midair.
If this doesn't address your concern, can you state more clearly what is making you worry? I might just not be getting it. |
