dreamaker99.wowway
So I know I am understanding this correctly. So if I hook a USB cable to the computer and then to the bottom port of the Pocket 2 then they should be able to communicate together. And if that is the case, why do you need a Smartphone to activate the Pocket 2, why can't you do it through the computer. I am trying to do some diagnostics to determine the problem, and whether the problem is me or the Pocket 2. Now if the bottom USB port can be use as data transfer, why doesn't the computer detect the camera.
Thank You |
