Video Sizes
531 4 2021-3-25
D. Caviness
Quick Question - Is there a way to adjust the size of the video before the app cuts and start a new video?  I'm flying a Mavic Air 2 with a 256GB microSD and I would like a continuous video without it being auto cut in 3.5GB chuncks.
Thanks
2021-3-25
DAFlys
No way to currently change it,  its due to compatibility as many file systems cannot hold a file bigger than 4gb.
2021-3-26
D. Caviness
DAFlys Posted at 3-26 00:19
Thanks for the information!
2021-3-26
DAFlys
D. Caviness Posted at 3-26 00:32
You're very welcome.
2021-3-26
DJI Stephen
Hello there D. Caviness. Good day and thank you for these information you have provided. The maximum capacity of a single file will not exceed 4GB. If exceeded, the recording will be stopped, and a new recording will be started. In addition, the maximum file size of FAT32 is 4GB. Hence, a file that is larger than or equal to 4GB will be divided, otherwise, the file may be lost or abnormal and cannot be read. Although exFAT allows a larger file size, the larger file may be damaged due to abnormal power-off and SD card removal, or even cannot be recovered. So the storage of the camera is 4GB regardless of the file systems. So it is normal the video will be split if it reaches 4GB. Thank you.
2021-3-26
