Buzzyone
Flight distance : 4647913 ft
Having read your post again, it sounds like you have managed to switch your goggles to the FPV System, to connect to the FPV drone you will need to switch it back. If you are in the FPV system in the goggles, go to devices and select DJI FPV Drone, and then restart the goggles. They should syart with the FPV Drone system software which will have the italic text and red warning banner.
You will need to rebind the FPV Drone to the goggles first - Power up the drone, once its ready if you don't get an image then press and hold the battery button on the drone until it beeps and you get the battery lights flashing in sequence. On the goggles press the red bind button next to the power connector the goggles will beep and then bind to the drone, you then need to press the battery button again on the drone until it beeps and flashes the battery lights. Power up the remote and then press and hold the power button on the remote until it beeps and re-pairs to the drone.
Refer to page 14 in the User Manual for the drone.
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
https://dl.djicdn.com/downloads/ ... s_V2_User_Guide.pdf
