Range and MC interference
2400 6 2021-3-31
DaBagBoy
Flight distance : 151135 ft
I'm losing video transmission at about 600m when flying with the motion controller. So far it's consistently gone into RTH mode and flown up then back to me to re-establish video connection.
BUT I wondered how far I should be able to fly with the motion controller? and if the MC interference could be contributing to the cut outs?
2021-3-31
mc54
Flight distance : 1030 ft
I'd be curious as to where the antennas are located in the motion controller and if they aren't as big or effective as the ones in the hand controller....
2021-3-31
DJI Stephen
Hello there DaBagBoy. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try flying your DJI FPV to a different location to see if the issue will still persist? The DJI Motion Controller uses the OcuSync 3.0 image transmission technology, with the maximum flight distance of up to 10 km. Thank you.
2021-3-31
DaBagBoy
Thanks, I've been at 4 very different locations in the past few days and so far and have seen it at each location, I don't see the MC Interference notice with the remote controller only the motion controller
2021-4-1
Plasmo
Flight distance : 17907 ft
DaBagBoy Posted at 4-1 05:25
My Motion Controller only allows me to go 1500 Ft in all directions.  I have tested this multiple times in different locations.  Is there a setting that unlocks further distance?  I do not have this range problem with the regular FPV controller that came with the combo kit.
EDIT: I fixed the distance issue.  There is a security setting that needs to be disabled for the Motion Controller, which mine was locked at 1640ft max distance.  Unlock this, and it fixed my distanced issue.
2021-4-4
fans10a683c0
Nigeria
Hi, I am having the same issue, plus a further warning that "Country Code is not updated". Can you pleaee share with me how you solved the securtity feature problem. Thanks
2021-4-22
djiuser_TPJjC1801Kiz
I’m having the exact problem as everyone else. With the motion controller I’m getting very limited distance as well as the interference message no matter where I fly. But I’m having no issues with the normal controller.
2021-6-3
