djiuser_9suagLcP6AGK
Buzzyone Posted at 4-2 12:44
I had a small mishap with mine (basically a high speed run close to the ground, clipped a tuft of grass) the drone and the battery parted company. Not sure its a design problem I suspect more of a physics problem! Battery and drone were next to each other as the ground was very soft there was no damage.
How fast were you going, was the drone damaged? the battery would have continued in the direction you were travelling if it wasn't ejected vertically.
I was going probably about 20mph, the height it came down was about 20-35ft. I crashed into a field of grass. My drone was undamaged and flies perfectly fine but the battery still missing |
