eisenfliege
Duane Degn Posted at 4-18 08:01
I posted my theory of why this happens here. There's also this post where someone said loosening the screw made the error go away.
In case you haven't seen it, I've posted photos of the controller's internals here. Some of the photos might help you see where the little internal buttons are located.
Thanks, @Duane for this hint. As soon as we have some better weather here, I'll test what I can change with those two screws and if this affects.
I'm wondering how the TX is detecting that there should be a mechanical issue - you can measure the
resistance of the gimbals but this needs to be some kind of dynamic interpretation, or is there another build-in sensor?
Edit: I've looked into your disassembled picture - your interpretation of the little switch makes sense - this may be the sensor I was looking for.
