Tablet cable for air 2s
1260 8 2021-4-26
fans1adbdd02
Has anyone bought a 10 to 12 inch cable that works with a tablet. I bought a c to c cable and it didn't connect . I connected the DJI cable and they work fine together. The tablet and controller are conpatible , its the cable.
2021-4-26
GaryDoug
Flight distance : 1292802 ft
I use this one with my MA2 and an ASUS 8" tablet and mount:
https://www.amazon.com/gp/produc ... title?ie=UTF8&psc=1
Note the hole I cut in the adapter mount plate to keep the cable from being too tight.
2021-4-26
fans1adbdd02
Thanks for getting back I had just ordered this one and if this one doesn't work I'll try the one you have.  https://www.amazon.com/gp/product/B089CQNF38/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
2021-4-26
GaryDoug
fans1adbdd02 Posted at 4-26 18:40
That should work. Was not available last year at this time ;-)
2021-4-26
fans1adbdd02
That makes me feel good, Thanks again
2021-4-26
DJI Stephen
Hello there. Good day and thank you for reaching out. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if those cables that you need is available. In addition I hope that you can get some recommendations from our DJI Co pilots with regards to this inquiry. Thank you and please be safe always.
2021-4-26
fans1adbdd02
GaryDoug Posted at 4-26 18:42
That cord came and it was made for Dji and a tablet.  It had the a controller embossed on the end of one of the connectors so you don't hook it up backwards. You would think it would matter but it does . I hooked it up backwards when put it on and it did work .I  flipped it around and hooked right up. The connectors look just like DJI oem
2021-4-29
GaryDoug
fans1adbdd02 Posted at 4-29 15:58
Thanks for the feedback. It helps a lot of us.
2021-4-29
SjK_oldman
Flight distance : 73583045 ft
Cable Creations make the best cables.  I find that they work best with all my drones.
2021-4-30
