Problem with track mode duration
322 0 2021-4-27
Onko1
Serbia
Hi,
I noticed that the track mode has certain problems regarding the duration between the two points. I created a few examples and made sure of it. The simplest example is
Point   Duration  Stay time
    1      N/A             0
    2      20 s            0
I expected duration of 20 sec. However, when I turn on the record button, the movement takes about 17 seconds. Also duration of video is the same - 17 sec.
How is it possible to overcome this mistake.
Thank you.
2021-4-27
