PAir2s
Flight distance : 68816 ft
Poland
yes i did re-firmware of the controller by dji assistant 2, nothing helps. Of course, this loud beep beep occurs 1-3 times out of 10 times when the controller is turned on. It is tiring.
I have the impression that the first dji air2s models are underdeveloped.
i had dji mavic air after mavic air2 and had no problems 2 years with any problems.
I bought a more expensive newer model and I have a lot of problems.
I have bought dji care for 2 years and there is help, but what they write, what I have to do, it does not work.
I think we should start a topic about the problems of the new drone.
I have the following:
1. Altidude zone 0m in places where there are no danger areas. When flying Air2 and Air2s in the same place, air2 does not have this message, air 2s has a message about stupid altitude zone 0m ! wtf ?!?
2. definitely more difficult and longer searching for a connection with satellites...
3.beep beep beep on the controller
4.lower range video with OC3 ? (I fly the same route as air2 and air2 flies without interference, air2s sometimes loses signal or freeze video )
5. The battery is definitely worse
6. I think air2s is louder than air2
The first 4 points are the most frustrating.
The fact that he has a better camera, I don't know if it's really worth the money.
at the moment I feel disgusted and a bit cheated. Because I bought a more expensive model, but is it better? I think not
