SD card issues
512 4 2021-5-2
Busker12
Flight distance : 165154 ft
Hi, really sorry if this has bee a hot topic in the past.  The SD card Sandisk extreme, I have used in the past in my Mavic Air 2, was working and now does not.  I have updated the firmware on the DJI assistant, so i'm up to speed.  I have tried another card and that also say 'No SD Card'.  I have formatted both cards on a Gopro and as far as I can see they are clear.  This is a brand new Mavic, bought yesterday!, not happy.
Any suggestions would be grately appreciated.
2021-5-2
DJI Stephen
Hello there Busker12. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try using a different recommended microSD card to see if the issue will still persist? In addition, kindly please connect your DJI Mavic Air 2 to your computer with the microSD card plugged in, turn it on, and check whether the microSD card can be detected by the computer. If it can't be detected, I would recommended for you to contact our DJI support team at https://www.dji.com/support for further assistance. We have a team that will do there best to evaluate the said DJI drone and will give out the best resolution for this issue. Again I am sorry for the trouble and thank you.
2021-5-4
Geebax
The card that does not work, try to format it in the aircraft. If it does not format, then the SD card interface in the aircraft is probably faulty.
2021-5-4
Busker12
DJI Stephen Posted at 5-4 20:37
[view_image]
Thanks for the reply, I have spoken to dji support and they have advised me to return the drone to the place of purchase, which I have done. The replacement is all ok.
2021-5-4
Busker12
Geebax Posted at 5-4 21:19
Dji couldn't help, returned it and got a replacement. Thanks for your suggestions.
2021-5-4
