johnwarr
Flight distance : 6467 ft
Because if it was under 500m you would have been able to keep it in sight and you would have had the video feed to see where it was.
Anyway, if it was less than 500m and over fields, then you should be able to find it easily, take the last point you had video and go from there following the planed route.
Are you sure you set enough altitude to clear any trees or other obstacles on the way ?
How long into the mission did you lose fpv ? |
