Muzanshin
JJB* Posted at 5-16 12:11
Hi,
In Europe height limitation in most countries = 120 meter above ground level where you drone is flying! , so height enough to fly yourself free of any dangerous situation..... ;-)
The problem I am running into is that the DJI software calculates the max height from the launch point and not above where the drone is flying. This means if I launch and fly directly up 120m and then proceed to move horizontally, it will eventually ground itself due to being unable to fly higher than the limitation from the original launch point; i.e. flying up slope on a mountainside.
This means if you end up flying near mountain bikers, hikers, climbers, etc. that are at a higher elevation than where you launched, there are extremely limited options for maneuvering around them.
However, if you launch the drone from a higher position on the hill/mountain slope, you can fly 400ft above that and back down to your original launch position, as well as back up again (despite being able to fly up there originally), due to calculating a "negative" altitude.
Technically in the U.S., the FAA rule is 120m/400ft above actual ground level, which excludes extending that height above structures such as buildings by that amount (floors of a building are above ground level). There are some limitations measure from an altitude ceiling (something like 500ft from cloud level? Which is like somewhere around 10,00ft) for the class of airspace, but most drone pilots don't seem likely to ever reach them.
I'll see if I can post a video of what I mean at some point; it will be away from people to avoid potential hazards at the altitude, but should still clarify. |
