FB: GeoDrone4K
Flight distance : 2733720 ft
Romania
You try to play from MicroSD, or copy to HDD the movie?
You have MP4 or Mov selected at recording? Some Apple works better with MOV extension, no matter if is H264 or H265.
There is no issue with your laptop, can play H265 as DECODING is not such big thing, ENCODING is....some members did not find out about this...Just try to change the app that play the movie. (some use HW decoding, some does not).
The first thing to do is that: Record 4K H265 MOV, save the movie from drone through USB cable to HDD, check the movie....then copy from HDD to a USB, insert in a TV, check the movie.
It will be a trial in order to eliminate one by one the potential problems.
PS. The MicroSD should be capable to write at 14 Mb/s....test it...copy a large file and watch the speed...if is not, 1st thing to do = change the MicroSD. (don't care if is on package that READS with 100Mb/S....you write on it, that is a fake advert with Reading instead of Writing).
