DJI Diana
Flight distance : 2408 ft
ptombola Posted at 5-19 23:32
HI, I have a Mavic Pro 1. in order to fly in italy I need 3 different numbers, the FCS (flight controller), the APR (chassis number) and the GCS (ground control station). I found the APR on the drone where the battery goes, I found the FCS in the app under about and I don't have the GCS which was meant to be at the back of my controller but it's not there. can you help me retrieve that if I give you the other 2 numbers? thanks!
May I know if the controller is the original one that comes with the drone? If so, you can provide the serial number of the drone to me, I will check the serial number of the controller for you. |
