Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
GaryDoug Posted at 5-21 22:04
I once tried to track a Mini with an MA2 and it did not work (different devices). As said above, too small and more importantly....not a type of target that is supported type (person, vehicle, or boat)...and no, I don't know how it tells the difference ;-)
I've done something similar.
I used one of the drones as a gps-tracker, and have the 2nd drone to follow that. I've used it for calculating the gps-lag/occusync and testing my followme app. Kindoff replaced the gps info from a trackeer device with the gps-info from the drone instead.
I actually planned for a feature like that in my custom app, which never gets finnished :-)
It gets quite complicated though, since you have to run two separate instances of the app on different remotes/phones, and have them communicate through wifi. But it works. Be prepared to put in some work, because it's not that straight forward as it seems with a first look, at least if you do it from scratch.
I don't think you will have any luck with activetrack, but I can be wrong, I havn't tried it. |
