Gimbal going crazy after 01.01.0610 Firmware update
892 2 2021-5-22
djiuser_74arYKRBUG2A
DJI team,
I really need you help.
I have already tried the following.
  Powered everything down and done full reset
  Tried to do Gimbal calibration, but it failed. (both in automatic and manual (here it did not respond))
  Tried to downgrade firmware with Assistant 2, but the old version was not avilable for me to downgrade to.
  Reinstalled DJI Fly app
  Reinstalled 01.01.0610 firmware
Upward and downward control from the RC handset do not move the gimbal. Re-center gimbal does not respond.
Errors on app given are Gimbal stuck 40002 and gimbal overload 40003.
But as said none of this was a problem until I updated the firmware
help needed
thanks
2021-5-22
Corinne.
Flight distance : 6555 ft
You can remove the SD card if there is one and power on the drone again. You can also do IMU calibration. Hope it helps.
2021-5-23
#Corinne - thanks for the suggestions - tried both, no improvement
2021-5-24
