DJI_Orlando
Hello!
I am following this sdk and application integration tutorial and I am encountering an error when trying to run the app. The error I get is the following:
A/libc: Fatal signal 11 (SIGSEGV), code 2 (SEGV_ACCERR), fault addr 0xeaec1000 in tid 9830 (om.dji.andronid), pid 9830 (om.dji.andronid)
W/om.dji.andronid: type=1400 audit(0.0:345): avc: denied { execmod } for path="/apex/com.android.runtime/lib/bionic/libc.so" dev="loop10" ino=17 scontext=u:r:untrusted_app:s0:c158,c256,c512,c768 tcontext=ubject_r:system_lib_file:s0 tclass=file permissive=0 app=com.dji.andronid
Does anyone know what causes this error?
The error seems to be linked with the line Helper.install(MApplication.this)
package applications;
import android.app.Application;
import android.content.Context;
import com.secneo.sdk.Helper;
public class MApplication extends Application {
private DemoApplication demoApplication;
@Override
protected void attachBaseContext(Context paramContext) {
super.attachBaseContext(paramContext);
Helper.install(MApplication.this);
if (demoApplication == null) {
demoApplication = new DemoApplication();
demoApplication.setContext(this);
@Override
public void onCreate() {
super.onCreate();
demoApplication.onCreate();
this is my gradle.build(app):
plugins {
id 'com.android.application'
apply plugin: 'kotlin-android'
android {
compileSdkVersion 30
buildToolsVersion "30.0.3"
defaultConfig {
applicationId "com.dji.andronid"
minSdkVersion 19
targetSdkVersion 30
versionCode 1
versionName "1.0"
multiDexEnabled true
testInstrumentationRunner "androidx.test.runner.AndroidJUnitRunner"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
dexOptions {
javaMaxHeapSize "3g"
packagingOptions{
doNotStrip "*/*/libdjivideo.so"
doNotStrip "*/*/libSDKRelativeJNI.so"
doNotStrip "*/*/libFlyForbid.so"
doNotStrip "*/*/libduml_vision_bokeh.so"
doNotStrip "*/*/libyuv2.so"
doNotStrip "*/*/libGroudStation.so"
doNotStrip "*/*/libFRCorkscrew.so"
doNotStrip "*/*/libUpgradeVerify.so"
doNotStrip "*/*/libFR.so"
doNotStrip "*/*/libDJIFlySafeCore.so"
doNotStrip "*/*/libdjifs_jni.so"
doNotStrip "*/*/libsfjni.so"
doNotStrip "*/*/libDJICommonJNI.so"
doNotStrip "*/*/libDJICSDKCommon.so"
doNotStrip "*/*/libDJIUpgradeCore.so"
doNotStrip "*/*/libDJIUpgradeJNI.so"
doNotStrip "*/*/libDJIWaypointV2Core.so"
doNotStrip "*/*/libDJIMOP.so"
doNotStrip "*/*/libDJISDKLOGJNI.so"
pickFirst 'lib/*/libstlport_shared.so'
pickFirst 'lib/*/libRoadLineRebuildAPI.so'
pickFirst 'lib/*/libGNaviUtils.so'
pickFirst 'lib/*/libGNaviMapex.so'
pickFirst 'lib/*/libGNaviData.so'
pickFirst 'lib/*/libGNaviMap.so'
pickFirst 'lib/*/libGNaviSearch.so'
exclude 'META-INF/proguard/okhttp3.pro'
exclude 'META-INF/rxjava.properties'
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
dependencies {
implementation 'androidx.appcompat:appcompat:1.3.0'
implementation 'com.google.android.material:material:1.3.0'
implementation 'androidx.constraintlayout:constraintlayout:2.0.4'
testImplementation 'junit:junit:4.+'
androidTestImplementation 'androidx.test.ext:junit:1.1.2'
androidTestImplementation 'androidx.test.espresso:espresso-core:3.3.0'
implementation "androidx.core:core-ktx:+"
implementation "org.jetbrains.kotlin:kotlin-stdlib-jdk7:$kotlin_version"
// SDK dependencies
implementation 'androidx.constraintlayout:constraintlayout:1.1.3'
implementation 'androidx.lifecycle:lifecycle-extensions:2.0.0-rc01'
implementation 'androidx.multidex:multidex:2.0.1'
implementation 'androidx.recyclerview:recyclerview:1.0.0'
// UXSDK dependencies
implementation 'androidx.annotation:annotation:1.0.0'
implementation 'androidx.appcompat:appcompat:1.0.0'
implementation 'androidx.core:core:1.0.0'
implementation "androidx.core:core-ktx:1.1.0"
// UXSDK map dependencies: Only include dependencies for map providers that are used in your app
// Amap: Do not include if publishing to Google Play Store
implementation 'com.amap.api:3dmap:6.9.2'
implementation 'com.amap.api:search:6.9.2'
implementation 'com.amap.api:location:4.7.0'
implementation ('com.dji:dji-uxsdk:4.11')
implementation ('com.dji:dji-sdk-provided:4.11')
repositories {
mavenCentral()
