Installing Freewell filters onto Mini 2
2768 16 2021-6-8
Shirkaster
Flight distance : 146476 ft
Finland
I got freewell ND 1000 and 2000 filters for my Mini 2. I follow the instructions how to install them and I couldn't install ND 2000 filter at all. It would just slide upwards from the bottom. ND 1000 was fine for a few flights but today i noticed a white line on the bottom of my pictuers . The filter was not alligned well, and now it doesn't stay on the camera anymore. Did anyone have similar issues with those filters? Did I get a faulty set or is the whole concept a bit bad? Any solutions to it?
Cheers,
Mihael
2021-6-8
DJI Stephen
Hello there Mihael. I am sorry for the trouble this has caused and thank you for reaching out. I hope that you will get the best recommendation from our fellow DJI co pilots who owns the DJI Mini 2  and uses the said ND Filters ( Freewell ND 1000 and 2000 filters ) on the said DJI drone. Just a reminder that DJI does not recommend you to use 3rd party accessories like ND filters on your DJI Mini 2. These 3rd party accessories might affect the said the said DJI drone when in use. There is a possibility that these 3rd party ND Filters will be able work. However, since it's not tested by DJI we cannot guaranteed the stability of the said 3rd party accessories if it will work all the time with no issues and might void the warranty of the said DJI product. Thank you.
2021-6-8
Alvara74
Flight distance : 30364 ft
Its probably user error
2021-7-3
Alvara74
2021-7-3
Alvara74
Are you sure you place the hooks of the ND Filter in the proper place? It might be you put them a bit too deep
2021-7-3
Shirkaster
Finland
Alvara74 Posted at 7-3 09:58
Yeah, I bough Skyreat set and they fit well and stay on the drone, been using them on many flights. it seems that Freewell are just not as good.
2021-7-3
Alvara74
Shirkaster Posted at 7-3 10:02
Freewell is a better company than Skyreat in general but everyone has their preferences
2021-7-3
Alvara74
I was thinking of buying Skyreat filters since Freewell isn't available in my country on Amazon and I have to pay customs
2021-7-3
Alvara74
I've heard a lot of reviews of Skyreat filters falling off mid flight. Has this ever been the case with you?
2021-7-3
Shirkaster
Finland
Alvara74 Posted at 7-3 10:04
I had two long flight over the sea, 5 kilometres each , with Skyreat filters and many shorter over the land and haven't had any issues with them. Sometimes I leave filters on the camera while the drone is in the bag and it stays put. 0 issues.
2021-7-3
Alvara74
Shirkaster Posted at 7-3 10:10
Even with the gimbal turning to face down?
2021-7-3
Alvara74
Also is it possible for you to send me some sample images from Skyreat filters?
2021-7-3
Alvara74
I would love to see how they perform
2021-7-3
Alvara74
Thanks btw
2021-7-3
Alvara74
It is probably a manufacturing fault
2021-7-11
djiuser_PNAEdNqXY6l7
Flight distance : 7700 ft
DJI Stephen Posted at 6-8 19:43
Hello,  I bought this two freewell nd 1000 and 2000 as well and I have the same problem. It will not fully stick on the camera and there for have a light line on the bottoms use of the picture.
The skyreat filters are fitting as they should be.
I wonder if all the freewell filters have this problem?
2021-9-10
DJI Stephen
djiuser_PNAEdNqXY6l7 Posted at 9-10 05:36
Hello there. I am sorry to read and to know that you are having this issue and thank you for reaching out. Are you able to post some sample photos showing the said issue for us to see and assist you further? Thank you.
2021-9-13
