Labroides
Flight distance : 9991457 ft
Oto Posted at 6-18 00:15
GDPR type of difference, these photos were not meant for publishing.
I have post everything you need there is nothing wrong with these photos only the wrong GPS altitude above water surface.
I have posted everything you need there is nothing wrong with these photos only the wrong GPS altitude above water surface.
I've told you three times what I'd need to look into this.
I cannot understand the problem posting a couple of photos, because there is no issue posting a couple of photos.
Your objection is just ridiculous.
There is nothing wrong with these photos only the wrong GPS altitude above water surface.
There appears to be something wrong with the metadata that's attached to the images and that's what I want to investigate.
You don't seem interested in solving the issue.
Try for yourself if you have Mavic Air.
If I had a Mavic Air, I would.
