DJI Smart Controller Fly Range
3128 11 2021-6-20
ady76
Flight distance : 105932 ft
Malaysia
Dear DJI Support Team,
Hi and good evening,
Recently, on 17 June 2021, I bought a new DJI Smart Controller for my Mavic 2 zoom. I really like the smart controller. After setup and linked to my Mavic 2 zoom, everything just works fine. The only 1 reason, I write this to DJI support is that, within the range of 1.2 km distance, I often lost signal between DJI Smart Controller and Mavic 2 Zoom drone. However, if I switched back to Standard RC, the signal between RC and Mavic 2 zoom drone is far better than DJI Smart Controller. The Mavic 2 Zoom even can fly up to 5km with a solid signal. Is there anything that I have missed during the DJI Smart Controller set-up? I have tested both DJI Smart Controller and Standard Remote Controller at the area, open field where the area has fewer obstacles.
I really appreciate your soonest assistance.
Best regards,
Ady
DJI SC
DJI SC
2021-6-20
DJI Paladin
Flight distance : 318 ft
Hi there. We're sorry for the trouble. Can you please try to download the DJI Assistant 2 software on your computer and update/refresh the firmware of your DJI Smart controller to see if the issue persists? Also, please try to fly to a different location using your DJI Smart controller after the firmware update for us to check if there would some changes. Please keep us posted. Thank you for your support!
2021-6-20
ady76
Malaysia
DJI Paladin Posted at 6-20 19:07
Hi. Thanks for your reply. Below is the update.
1. Firmware update using DJI Assistant 2 the latest version for Mavic.
2. During updates, experienced quite a number of times, network error. Even I connected to internet.
3. DJI Smart controller reboot itself a few times. This ok. but final firmware installation reboot causes the DJI Assistant 2 to disconnect with DJI Smart Controller, when updating the process at 98% completed. DJI Assistant indicated that "unstable connection" advise to recheck the version on the firmware page.
4. I have done the update 2-3 times.
5. I have update/refresh firmware for the drone Mavic 2 too.
6. Range test at a different location. Video feed starts to lagging when reaching a distance of almost 1.5km. However, the connection between DJI Smart Controller and Mavic 2 still good.
** Please check DJI Assistant 2 connection with DJI Smart Controller, as the connection indicated "unstable connection", everytime updating DJI Smart Controller via DJI Assistant 2
2021-6-21
ady76
Malaysia
** Please check DJI Assistant 2 connection with DJI Smart Controller, as the connection indicated "unstable connection", every time updating DJI Smart Controller via DJI Assistant 2
2021-6-21
ady76
Malaysia
ady76 Posted at 6-21 21:02
Hi good evening.
had done few things to try to resolve video feed lagging on DJI Smart Controller, within the range of 1.5km.
1. recalibrate the IMU on the Mavic 2 zoom drone
2. recalibrate the compass on DJI Smart Controller and Mavic 2 zoom
after which, the problem still the same. Within 1.5km video feed still lagging. Can DJI Support help on this issue, please? Thank you.
2021-6-23
Alvara74
Flight distance : 30364 ft
It might be that you're encountering some interference on the Smart Controller
2021-7-3
Alvara74
Or you haven't updated the controller fully
2021-7-3
Alvara74
Are you sure you flew with both controllers in the same direction?
2021-7-3
ady76
Malaysia
Alvara74 Posted at 7-3 09:52
Hi.
yes. flew the same direction. Range/video feed tested on both controllers separately. Thanks
2021-7-5
Alvara74
ady76 Posted at 7-5 04:38
Hi.
Well Idk why the range is a problem then
2021-7-5
Alvara74
Hi.
2021-7-5
DJI Paladin
ady76 Posted at 6-23 18:12
Hi good evening.
HI, Ady76. Sorry for the late response and we're sorry for the trouble. Since you already did all the possible troubleshooting steps that could possibly rectify the issue, and still the issue persists. I'm afraid that you may consider sending your DJI Smart Controller in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your support!
2021-8-8
