Extra Mini 2 batteries?
Alvara74
Flight distance : 30364 ft
Hey, I'm thinking about buying the DJI Mini 2 Fly More Combo and I was curious if anyone ever felt the need for a 4th battery?
2021-7-3
Frank Alonso
Flight distance : 785049 ft
I have had my Mini 2 for about two months now and have not needed a fourth battery.  That being said I have charged the batteries in the car when traveling.
2021-7-3
Matite
Flight distance : 61096 ft
I purchased the fourth battery from eBay for cheap but only because the hard case had a slot for it... never really needed more than two batteries so far to be honest.
DJI_Mini_2_Hard_Case
Note the little yellow pin is so I can keep track of which battery to use next (I use them in order one after the other so overall they all get used the same amount).
Here is the link to the case on Amazon AU for anyone interested:
https://www.amazon.com.au/gp/product/B08MXL67MS
2021-7-3
DJI Paladin
Flight distance : 318 ft
Hi there. Hope that you could get the best recommendation from our fellow DJI Pilots here that own the DJI Mavic Mini 2. Cheers!
2021-7-3
Alvara74
Frank Alonso Posted at 7-3 15:02
How long does it take you to charge all three batteries in the car?
2021-7-4
Alvara74
Does it take the same time (6 hours) or more/less?
2021-7-4
Alvara74
Also, do you need to buy a separate car charger?
2021-7-4
Alvara74
Matite Posted at 7-3 15:59
[view_image]
I'm saving up Forum Points which I would then convert to DJI Points to buy an accessory
2021-7-4
Alvara74
But I can't think of anything else other than a battery
2021-7-4
Alvara74
Do you have any suggestions?
2021-7-4
Alvara74
Also, is it necessary to use all batteries the same?
2021-7-4
Alvara74
And how did you label those batteries? Did you stick a piece of paper on them?
2021-7-4
Alvara74
DJI Paladin Posted at 7-3 20:46
Yeah, I'm getting good recommendations, thanks!
2021-7-4
Matite
Alvara74 Posted at 7-4 02:14
You could use a label maker but I just wrote on them with a Sharpie.
2021-7-4
Alvara74
Matite Posted at 7-4 02:51
I might do the same, thanks!
2021-7-4
DJI Paladin
You're welcome. Thank you for your support!
2021-7-5
Alvara74
DJI Paladin Posted at 7-5 00:56
No worries and thank you too!
2021-7-5
HighInBC
Philippines
I can certainly use up my 3 batteries, or at least want a full one when I only have 1/2 full ones. The spot inside the drone seems like wasted space, I do want to get another battery.
2022-1-3
