Alvara74
Flight distance : 30364 ft
DJI Paladin Posted at 7-10 20:07
Hi there. Thank you for reaching out. The DJI Mini 2 can fly without a GPS signal, however, the safety feature of the DJI Mini 2 will enable and limits the height to 5 meters for safety purposes. Also, the interference from other sources might trigger the drone to move uncontrollably. In addition, the Vision System of the DJI Mini 2 allows the aircraft to hover at low altitudes ( 0.5 to 10 m ), but the ground must have distinct textures, and there needs to be sufficient lighting. Hope this helps. Thank you!
Does it automatically take off, or do you have to disable something? |
