Horizon level problem Mavic Air 2
709 3 2021-7-26
djiuser_p1nzF5bOk76e
Flight distance : 1300705 ft
Russia
Hello!
After little crash without mechanical damage,
Camera does not keep horizon level - little deviation 1-3 degrees depend on the wind force.
When dron switch on in my hand (not in fly) horizon level is ok!
In fly dron is full stable, absolutely ok, but camera has deviation horizon lever.
All calibration procedures by Dji Fy do not have good result.
2021-7-26
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Since there was a crash that happened before on your DJI Mavic Air 2 before and now you are experiencing these issue. It would be best to contact our DJI support team at https://www.dji.com/support for further assistance. We have a team that will do there best to assist you and give out the best resolution for this issue. Again I am sorry for this trouble and thank you.
2021-7-26
Rasmusjakob
Denmark
I have a similar problem - although it is with a DJI Mavic 2 Zoom. For no obvious reason (no collisions, crashes, physical damage or other) the horizon is suddenly slightly off (approx. 3 degrees). I have recalibrated both IMU, compass and gimbal/camera (DJI Assistant 2 for consumer drones) as suggested by the retailer, but to no avail. Any suggestions?
2022-10-10
DJI Wanda
Rasmusjakob Posted at 10-10 07:17
Hello, there. Sorry for your inconvenience. May we know more information when you try to do calibration?
2022-10-11
