droneflyers.com
Flight distance : 60709 ft
Your R/C still works in these situations - so don't panic! You have full control of the aircraft....
What device are you using?
What did you switch off and on several times?
Hints:
1. Turn off VPS
2. In the lightbridge settings, select custom channel and try a fixed channel (I use 20).
If this does not work, land the aircraft and reset everything. |
