New RSC 2 Firmware Released (17/08/2021)
3191 14 2021-8-17
DJI Support
Flight distance : 2408 ft
Overview
Date: 2021.08.17
Firmware: v01.03.00.20
RavenEye Firmware: v01.02.00.20
DJI Ronin App iOS: v1.4.9
DJI Ronin App Android: v1.4.8
User Manual: v1.0
What’s New?
• Fixed issue: camera view was blank after recording stopped when using some Canon cameras.
• Fixed issue: shooting mode switched from video to photo unexpectedly after recording stopped when using some Canon cameras.
• Optimized performance in Underslung and Flashlight mode when shooting at low angles.
Notes:
• Motor parameters are reset after updating firmware. Make sure to autotune DJI RSC 2.
• Make sure that the DJI Ronin app is the latest version when updating the firmware.
• Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update process.
• Update the firmware for the DJI RavenEye Image Transmission System using the DJI Ronin app by connecting the RavenEye via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RavenEye Image Transmission System during the update process.
• If DJI RSC 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
• If the firmware update fails, restart DJI RSC 2 and retry.
2021-8-17
Frontliner 2020
Philippines
thank you for the new update...
2021-8-17
DJI Stephen
Frontliner 2020 Posted at 8-17 01:28
Hi there Frontliner 2020. Thank you for the reply and you are very much welcome. Have a safe and a happy filming always. .
2021-8-17
ralphp
Flight distance : 741 ft
New Caledonia
Thank you but can we get Capture Photo on SONY A7C anytime soon ?
Keep up the good work.
2021-8-17
Gd小猪
Flight distance : 678609 ft
ralphp Posted at 8-17 15:56
The release record of the last large package version already supports A7C taking pictures. You can upgrade the new firmware to view, good luck.
2021-8-17
ralphp
New Caledonia
Gd小猪 Posted at 8-17 18:22
You are right ! I can use Panorama and creative functions now. Thank you.
2021-8-17
Gd小猪
Thanks, great update.
2021-8-17
Gd小猪
ralphp Posted at 8-17 19:20
Need to pay attention when taking photos,How to avoid losing photos when taking photos: Select Network > Transfer/Remote > PC Remote Control > Still Img. Save Dest. > Camera only.
2021-8-17
Omid_P
Iran
Thank you ! Thank you ! Thank You ! I appreciate that you solve my big problem with this new update,    but playback button still not work on my Canon 90D _ RSC 2
2021-8-18
Gd小猪
Omid_P Posted at 8-18 14:19
Are you saying that you can't play it after plugging in the camera?
2021-8-18
Omid_P
Iran
Gd小猪 Posted at 8-18 19:48
After I press stop recording button on gimball, I can't check and see my record , I do this by pressing playback button on camera !and it not work ! Is there another way to check !?
2021-8-19
Gd小猪
Omid_P Posted at 8-19 00:24
Are you connecting an HDMI device?It's best to upload a video, let me see if I can help you.
2021-8-19
Omid_P
That's kind of you !
I know that !
Sometimes I use Raveneye and HDMI! And it works fine But most of times can't use it because of time , I just use gimball and camera with RSS cable
2021-8-19
Gd小猪
Omid_P Posted at 8-19 04:15
I know that !
You can't watch what you said. What's the problem, can I watch the video?
2021-8-19
Treebore
Flight distance : 260194 ft
Gd小猪 Posted at 8-19 18:14
I have a rs2 with raveneye camera is lumix g9 withe latest 2.4 firmware all cables connected correctly pictures on screen and on phone but the active rack speed is all ways at 30  it will not track correctly at 30. Any ideas?  One thing I did try is downgrade firmware on rs2 to 1.03.00.50 that’s works ok and activtrack works as is should   1-30 and stays what I put it on strange anyway firmware 1.04.00.20  has a problem with active track  can anybody help out with this please
2021-8-26
