K6CCC
Flight distance : 651683 ft
In any RTH operation, the drone will first climb to the RTH altitude setting - unless it's already above that in which case it will stay at the higher altitude.
Next is that in the event of a loss of signal, there are three options you can set: Land immediately, Return to Home, and Hover. Note that if the drone is within about 20 meters of the home point, it will land where it is rather than return to home.
Gotta run...
