DJI Wanda
Hello, Drifters. Sorry for your inconvenience. Please kindly know that the noise is normal when you use aircraft for some time. If you worry about the noise, please check the aircraft as the instructions below and record a video for us:
1. Under a quiet circumstance, place the aircraft on the level ground, de-attach the propellers and boot up the aircraft.
2. Please carefully listen to each motor, observing whether there is a sound that came out of metal friction; If you really hear the sound liken to friction or bump due to some foreign objects, please see step 3.
3. Please record the video for more than 20 seconds, 50 centimeters above the aircraft with the microphone of the device not being covered by anything.
Please keep us updating! |
