pan51
I made it, finally (lots of hours spent)!
What did I do?
a. get a VMWare Fusion 12.1 player (trial sufficient)
b. get a Win10 Home ISO image
c. create a Win10 VM, use NAT for VM to Mac network connection
d. install latest DJI Assistant 2 for FPV on VM and start
Now the interesting part: I tried several USB-C to USB-C cables to connect the goggles, however I never saw the "LOST.DIR" of the goggles appear on the Win10 as a drive (I do saw it while trying on the mac using exactly one of those cables).
At the end, almost persuaded myself to go to my ugly neighbors and their Win laptop, I tried the following: connected the Goggles to my Apple Cinema display (USB-C to USB-A),
the display itself is connected to my Mac by thunderbolt using a TB to USB-C. In the end it worked, Windows mounted LOST.DIR, installed some drivers, after that goggles were visible in DA2,
could be activated and new firmware installed.
I do not attribute that to the cinema display specifically but to it's function as an USB hub in this case. My assumption is, that it might work with (m)any USB hubs.
Axel |
