JP-Dronie
Flight distance : 177277 ft
India
I found the below post, on some other forum, and i decided to do the same, and this fixed the motor for me.
Basically, i removed the foam padding from below the motor, removed the 3 screws, and lifted the motor slightly.
then i took some liquid grease in a spoon, and dipped a thin pin into it, and put 1-2 tiny drops of that grease in the middle of the motor, where the bearing is.
Also added one drop on the top of the motor, in the middle where the motor is (not where the magnets are). just in the center.
Rotated the motor with hand for a few minutes. cleaned the bottom bearing with q-tip and applied 1-2 tiny drops of liquid grease again.
Thats it, the motor became smooth as before.
Just be careful to put only a tiny drop or two in the middle of the motor shaft were the bearing is, not anywhere else.
Below is the post i found on another forum. JUST FYI
"Yesterday the issue occurred again. I unfolded the drone and could feel the motor is again more difficult to turn by hand. As expected, when I tried to start the motors I got the "Motor unable to rotate" error message. Without going online to check the advice you gave me, I tried some things.
Firstly, I've noticed that if I turn the motor by hand for like 20 seconds (in any direction, or just repeatedly left-right half a turn), it would somehow 'loosen up' and spin more freely, almost like the other three motors. Then if I left the drone still for some minutes the motor would stiffen up again. I did this experiment for about 6 times, and every time manually rotating the motor would loosen it up. This happened both with the battery inserted or not.
The next thing that came to my mind is using a hair dryer. I left the drone still so that the motor was stiff again, and then lightly heated it up without touching(rotating) it. Surprisingly, this action would also loosen up the motor. At this point I had two theories:
The hot air interacts with the magnets, temporarily changing their power. When the motors was loosened up and spun easily, I could clearly feel the magnetic clicks, so something else was going on. The temperature was also too low for this, I believe.
Maybe something related to the grease/oil in the bearing. Heating the motor would maybe make the lubricant more fluid, resulting in an easier rotation. Repeatedly rotating the motor by hand maybe had the same effect.
Based on the second theory, I decided to try to slightly degrease the motor bearing. I removed the rubber/foam pad that covers the 3 screws of the motor. Unscrewed those and lifted the motor so that the bottom part was visible. A good amount of dark brown oil was visible there(not sure how that part is called), so I wiped the area with a Q-tip, being careful not to leave any cotton hairs. You can see this operation in the attached pics. In the second pic is the Q-tip, after cleaning the area. Finally, I soaked the tip of the propeller screwdriver in some isopropyl alcohol in order to leave 3 tiny drops of IPA around the shaft. Maybe a degreaser would have been more adequate, not sure. I then rotated the motor for a minute or so, then cleaned the area once again using a new Q-tip.
After putting everything back together, the issue seems to be gone. Every few hours I checked if the motor would stiffen up again, but it would not. I did some test flights, going through 3 batteries and everything seemed fine.
I'm not sure what the conclusion is. Maybe the bearing was overgreased? Maybe some very fine dust go into it, and I solved the issue by cleaning the area and applying IPA? Regardless, thanks again to all of you for your time and help" |
