Code 30068
1012 2 2021-10-16
edgarcxped
Flight distance : 761841 ft
Colombia
Since some flights, my AIR2s can’t take off because error 30068 in battery ( ensure battery is installed properly). Please help.
2021-10-16
DJI Gamora
Hi, there. Sorry to hear about the problem you've encountered. Please try the following steps:
1. Remove and then reinsert the battery. After hearing a "snap" sound, press hard on the battery to ensure that it is properly mounted.
2. Wipe the spring contacts on the battery and inside the battery compartment with a tissue.
3. If the DJI Fly app still prompts "Battery installation error." after multiple tries, please send the battery and drone back to our service center for testing. You could contact our support at http://www.dji.com/support to start a case.
Thank you for your understanding and support.
2021-10-16
Dwight Hewitt
Jamaica
brand new drone and you telling us to do that without any proper support
2021-12-16
