DJI Assistant 2 Not Progressing Past Tutorial Screen
1120 2 2021-10-19
cwjohnson201
Trying to calibrate my Mavic Pro 2 Zoom's visual sensors for the first time using DJI Assistant 2. I am unable to progress past the tutorial screen.
It says "Calibrating Now" but the render wheel just spins and the calibration grid won't pop up. See attached screenshot for the screeRLgQgAAEngMCdBGsIQAACwQj8D72LJhUiazYsAAAAAElFTkSuQmCC[/img]
2021-10-19
DJI Stephen
Hello there cwjohnson201. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value (usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200). Thank you.
2021-10-19
Sean-bumble-bee
Flight distance : 15997 ft
I think the mavic 2 requires the "Assistant 2 for mavic"  https://www.dji.com/uk/downloads ... ant-dji-2-for-mavic
2021-10-22
