flight altitude restricted to 5 meters
1259 13 2021-11-10
rulz
Flight distance : 386781 ft
Austria
I'd like to know why my flight altitude was restricted to 5 meters. I was in the mountains with no restrictions. The only thing I noticed was that I didn't have enough GPS satellites. Any comment will be appreciated!
2021-11-10
jmb63
Flight distance : 7009439 ft
Yup, Insufficient GPS will do that...I have had that happen.
2021-11-10
Sean-bumble-bee
Flight distance : 15997 ft
page 47 of the manual https://dl.djicdn.com/downloads/ ... anual_v1.0_enIV.pdf
"Flight Limits DJI Fly App
Max Altitude
Height is restricted to 30 m when the GNSS signal is weak.                           Warning: Height limit reached.
Height is restricted to 5 m when the GNSS signal is weak                                          ''
and light conditions is not sufficient."
Max Radius The restrictions on the radius are disabled and warning prompts cannot be received in
the app
Though there is an interesting bit beneath that  ''The altitude limit when the GNSS is weak will not be restricted if there was a strong GPS signal
when the aircraft was powered on.''
2021-11-10
DJI Stephen
Hello there rulz. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try flying your DJI drone to a different location where there us sufficient GPS for us to be able to see if the issue will still persist? Thank you.
2021-11-10
rulz
Austria
jmb63 Posted at 11-10 17:11
Thanks jmb63. I appreciate your comment!
2021-11-11
Hrodnand
Flight distance : 3038150 ft
Romania
On a side note, always wait for it to receive signal from at least 15 satellites before taking off, otherwise you risk the controls and positioning to malfunction.
2021-11-11
rulz
Austria
DJI Stephen Posted at 11-10 20:06
As soon as I can, I will!! I'll let you know.
Thanks for your prompt reply!
2021-11-11
DJI Stephen
rulz Posted at 11-11 03:20
Hi there rulz. Thank you for the reply and for this update. Kindly please keep us posted for further assistance. Thank you.
2021-11-11
Labroides
Flight distance : 9991457 ft
There is no single number of that you need to wait for.
Wait for the drone to record it's home point.
Sometimes that might require more than 10 or 15 sats, sometimes it could happen with less.
2021-11-12
JJB*
Flight distance : 12401030 ft
Hi,
Easiest way is to wait to see the GPS icon top right to colour from red>amber>white.
Amber = enough satellites to fly in a stabilized GPS mode. (numbers to colour amber - various)
At white = HP is set, ready for flying.
cheers
JJB
2021-11-12
rulz
Austria
DJI Stephen Posted at 11-11 21:40
Hi DJI Stephen, I had the change to burn some batteries last weekend ant everything worked perfect. All the comments are right, the problem was due to insufficient GPS (GNSS). I flew it up to 120 mts.
Thank you all for your contributions!
2021-11-16
rulz
Austria
Ramon Posted at 11-12 02:39
no inicie vuelo con menos de 10 satelites,saludos
Gracias Ramon!
2021-11-16
DJI Stephen
rulz Posted at 11-16 07:16
Hi there rulz. You are very much welcome and it is great to know that the issue has been rectified. If you have any other concerns or any inquiries with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2021-11-18
