FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
No, you cannot because we do not talk about home works here, but cinematic works.
Also the artefacts that appear from sharpness you cannot correct in post without affecting the whole quality.
Contrast is a MUST because in RAW you get the recovery of low light given by contrast settings then you can work with it, but if you don't have it, in post you need to work with LOG profile that I have already seen that is with problems in contrast (overcontrast = loose the 0-5% shadows).
So to answer your question: NO, some things needs to be done starting with RAW recording, not in post.
PS. Seems that MODS from DJI does not see this post or they just don't want to see it...???? |
