Sean-bumble-bee
Flight distance : 15997 ft
It's not obstacle avoidance in the way obstacle avoidance on the likes of the Mavic 2 Pro works but .........it does detect, if it can, how low it is over an object and it will maintain, if it can, a clearance of around 50cm until commanded to land.
So, fly it low AND SLOW at a slope and it will climb the slope. Ditto fly it low over the floor etc. and direct it over a low table etc. and it will climb as soon as it detects the table. Put you hand under the drone ( with in 50cm af the bottom of the drone and in the field of view of the sensors ) and the drone will climb away from your hand.
It also means that, in good light, you can descend vertically, from height, with the throttle fully closed and the drone will slow its descent as the ground comes within range of the sensors. DO NOT get used to the latter and then switch back to a drone that DOES NOT do this unless you remember the difference. I nearly 'descended' a Phantom 3 into the ground on the first 'refresher flight' after having been flying a Mavic Mini for a while. |
