Mystery Battery Discharge, Mini 2
343 7 2021-11-15
Greenz8
After having used my fairly new Mini 2 a number of times and having used the battery charging hub a few times as well, a mystery discharge of all three batteries has me baffled.  After the most recent use of one of the batteries I placed it in the hub with the others and plugged in the hub.  It cycled as usual attending primarily to the recently depleted battery.  When all three batteries showed a full charge I removed the cord allowing the hub to sit where charged.  Then,  a day or so later when attempting to use one of the batteries, the drone would not come on.  I tried another battery with the same response.  All three batteries were completely discharged.  I have since recharged all three and all three are holding thier charge now for three days.  Any idea what may have caused this apparent anomaly?  The only a couple of other factors that don't likely appear to pertain.  The hub was sitting atop a wireless printer that was not powered on.  And, after removing the charging cable from the hub, the unplugged end my have rested against the outside of the hub not close, however, to the connection.  Puzzled.
2021-11-15
Depp
Flight distance : 1868796 ft
The batteries automatically discharge after a few days down to about 65 %. That's normal because LiPos don't like to sit with a full charge. But a complete discharge is not what they're supposed to do. Don't know what caused that.
2021-11-15
DowntownRDB
Flight distance : 1722 ft
Could be a faulty charging hub.
2021-11-16
Greenz8
Depp Posted at 11-15 22:17
It's a mistry
2021-11-16
Greenz8
DowntownRDB Posted at 11-16 03:37
One would wonder.  Thanks.f
2021-11-16
DowntownRDB
Hope you get the issue resolved.
2021-11-17
DJI Stephen
Hello there Greenz8. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to charge the said DJI intelligent flight batteries on ce again on the said DJI charging hub to see if the said issue will still persist. If the issue persist, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do there best to help and will give out the best resolution for this issue. Again I am sorry and thank you.
2021-11-18
Greenz8
Thanks much.   Last few uses the hub and batteries are operating as intended.  Hoping that continues.  It was just weird.  I will follow your suggestion for further support if needed.
2021-11-18
