JohnDG
Flight distance : 1097270 ft
Malaysia
Montfrooij Posted at 11-17 00:25
PS, I'm using an iPhone SE 2020, so it should have enough specs.
(I think it is something in the drone, not in the device, but I could be wrong)
I don't think you're wrong.
Buffer overflow on the drone's internal memory and a bit slow to dump all the data. Not just AEB, pano's have the same problem.
Giving the choice to have only RAW could help, as I use JPG+RAW. The drone has to write the RAW picture, process the JPG (which I do not need) and write the JPG. A lot of useless handling that could be avoided. |
