Oblique route flight altitude setting in 3D multi-oriented mission
1571 2 2021-12-18
adwiputar
Cambodia
Hi,
I have just completed a 3D photogrammetry mission and was a bit shocked when suddenly the aircraft ascend to 100 m above the take-off level. In the setting, the only altitude parameter I could find was set to 35 m. I noticed that the aircraft complied with this during the nadir part of the mission but suddenly ascend to 100 m above the ground level during the oblique sensing. Is there any parameter I could set to specify the altitude during the oblique sensing on the GS RTK app or was it automatically set relative to the set mission altitude?
Cheers,
AD
2021-12-18
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
Maybe it's the safe altitude for the return home?
2021-12-22
patiam
Flight distance : 1118740 ft
I know this is an old thread but the setup for a "3D-Multi" mission has a separate setting for oblique portion altitude and the default is 100 m. It is right below the main (nadir) portion settings.
2023-2-21
