Controller and driver for Windows 10
6947 3 2021-12-21
Grugno
Hi everyone, I have a problem.
I would like to use the controller for the simulators (LiftOff). I connect the controller to the computer, windows 10 recognizes it as C5 but it tells me that the drivers are not available.
In fact, Liftoff finds it as HID Interface but it doesn't work.
Consider that I have not yet connected the controller to the drone and the drone to the glasses because I have received a defective battery.
I still did the firmware update via DJI Assistant 2.1 for FPV (ver.1.20).
Can someone help me? I would like to learn how to use the drone with the simulator.
Thank you
Ryzen 3900
Rtx 3090
32 Gb ram
MSI X570 chipset
Windows 10 not updated to 20H2
2021-12-21
DJI Stephen
Hello there Grugno. Good day and thank you for reaching out. I hops that our fellow DJI co pilots who uses the said flight simulators  (LiftOff ) can give out the best information and recommendation with regarads to this matter. Thank you.
2021-12-21
AzBachour
Flight distance : 151499 ft
Brazil
Hi, I had the same problem I was only able to make it work after activating the controller thru the DJI Assist 2.1 App
2022-9-30
djiuser_TfIqgLOIwpyS
So over 2 years and no answer? Or try to use the assist?
2023-3-27
