Nicodema
Flight distance : 90259 ft
Your gimbal seems fine, judging by the footage. Yes, the soft mount will allow you to wiggle the camera slightly, you're right there. It's more if it was "clonking about" which it doesn't sound like it is. In the first clip I can see snow blowing from left to right, indicating that there is wind, hence the lift to the left to hold station.
As for the footage playback, it's high bandwidth and your computer is not able to handle it. My MacBook Pro (Retina, 15-inch, Mid 2014, 2.8GHz Quad i7) is also not up to the job. It plays the first second or so smoothly, then starts to "chug". If I play the low res version that dropbox renders, that plays smoothly, so I know it's my machine. 4K p60 is a high data rate for machines other than up to date workhorses.
You will find rendering it down to 2k7 or 1080p will make it watchable. |
