Sean-bumble-bee
Flight distance : 15997 ft
EnjoyFlying Posted at 12-27 11:11
So, you use a phone with 1.5.4 to put in the EXP settings in your Mini 2, and then fly it with a different phone with 1.3. Good idea - but does it work? All of the EXP settings are stored in the drone ONLY, without 1.5.4 app they still work??
Would you share more, Thanks.
Yes that is what I did.
To test whether the changes are stored on the drone and were persistant I set the yaw to the maximum value, 0.9, ANY yaw command movement of the control stick away from the at rest position caused the maximum yaw rate, Safest option I thnk. In my experiments this setting persisted when I swapped phones. I think I also swapped controllers as well and the setting remained set.
Thinking on that, I do not remember if I switched the drones (mavic Mini and Mini 2) off and on at any point during these experiments. I will have to check that, my chosen working setting was 0.5, the straight line graph. As such it is probably not too different from the default so, if the drone reverted to the default on switch off & on, it might not be that obvious. |
