Need longer cable - Air2s to iPad Pro
351 2 2021-12-29
jmreim11
Hello - I'm a newbie on this forum and to drones.  Not sure I've posted this in the right place but trying to use my new Air2S with a 12.9 iPad Pro 4th Gen.  Problem is the connection cable that came from DJI isn't long enough.  I purchased an extension cable that seems to fit correctly on both ends but the connection is not being made (if I remove the extension and just use the DJI supplied cable that's too short, everything works perfectly).So my question is, can someone steer me to a specific cable that's long enough (about 18") and is known to work correctly?
Thx -
Jim
2021-12-29
DJI Stephen
Hello there Jim. Good day and thank you for reaching out. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if those cables that you need is available. In addition I hope that you can get some recommendations from our DJI Co pilots with regards to this inquiry. Thank you and please be safe always.
2021-12-29
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
Just create a new thread here : https://forum.dji.com/forum-129-1.html and select the right category / subcategory.
2021-12-30
