hychewright
Nicodema Posted at 1-8 02:50
If I've understood your plan correctly, i.e. add the air unit with its own battery to an airframe just to function as a VTx, then yeah, should work just fine. You may need to add some filtering to the air unit power, to reject interference from the other gear, but with it being separate you may not need it.
Thanks Nicodema, I though it would work be just to check with some pilots that has more experience with the Air Unit than I do. I'll try first without filtering and if I need then like you stated I'll add some filtering. Thanks again Nicodema and happy safe flying! |
