Mavic pro bad image quality
2340 13 2022-1-11
fans840bfc15
Flight distance : 1030 ft
For some reason my Maverick pro has a image quality problem when u turn the drone on it's clear then 5 seconds later it goes to fuzziness I've replaced the video cable the gimbal the gimbal board and the ribbons
2022-1-11
DJI Stephen
Hello there. I am sorry to read and to know that you are having this issue with your DJI Mavic Pro and thank you for reaching out. Since you arte having this issue with the said DJI Drone. I would recommend for you to contact our DJI Support Team at https://www.dji.com/support for further assistance. We will do there best to help and give out the best resolution for the said issue. Thank you
2022-1-11
Blériot53
Flight distance : 6188465 ft
Have you heeded the onscreen message "Firmware update required" ?
That may help?
2022-1-12
fans840bfc15
No I have updated to 1.4.500
2022-1-12
fans840bfc15
As soon as you turn the drone on it comes in clear then 5 seconds later it goes to this image
2022-1-12
Micato
Flight distance : 2057103 ft
Croatia
Could you check that "Over Exposure warning" is not ON,  in camera settings?
Your picture looks overexposed and your ISO and shutter speed looks weird.
Could you check Youtube videos type:  "Mavic pro camera settings"
2022-1-12
fans840bfc15
Micato Posted at 1-12 09:52
Here are my settings
2022-1-12
Micato
Croatia
I do not know how much expirience do you have with the Mavic and cameras so please do not be offended.
Can you set:   ISO to 100  and Shutter to between 300-1200 and take few pictures outside arround noon? With different shutter speeds but in that range 300-1200.
Did you watch YT videos that I recomended? I hope that I am helping.
Do your Mavic IMU calibration just to be shure.
2022-1-13
fans840bfc15
Yes I calibrated the IMU reflash the firmware tried
different shutter speeds and nothing so I'm thinking it's the core board because my Vision bar is not showing up on my hub I've changed the gimbal board both ribbon and wires one thing I haven't changed is the lens  if the machine stays off for a while and you turn it back on it's clear 5 seconds later it goes into a filter looking image
2022-1-13
fans840bfc15
Also forgot to mention when viewing the images on the SD card on the PC the image is clear
2022-1-13
Micato
Croatia
fans840bfc15 Posted at 1-13 10:25
By this told we can conclude that camera is OK. Maybe something with your DJIgo app on your display device. Did you try other android or IOS device?
2022-1-14
fans840bfc15
I tried it on a  iPad Air 2 I don't know if that's too old but same outcome I'm currently trying it on a LG v60  again thanks everyone for the help
2022-1-14
Blériot53
fans840bfc15 Posted at 1-12 05:53
Normally if you tap the screen on an area of interest the camera should focus there.
Maybe this indicates a fault
2022-1-15
fans840bfc15
Turns out I had a bad core board with a video processing problem
2022-1-20
