djiuser_tIEeUHn46m6L
Brazil
DJI Stephen Posted at 1-12 19:56
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please use a recommended charger ( FCC/CE certified USB charger rated 12V or 15V ) to charge your DJI RC Pro. It will take approximately 2 hours to fully charge the remote controller using a recommended USB charger rated 12V and one and a half hours using a recommended USB charger rated 15V. Thank you.
I use DJI charger, the same of mavic 3, the problem was that for some bug my rcpro wasn't activated, and there isn't a button as any device, click here to activate. I need to downgrade on DJI assistant 2, to 1.00.003, factory reset (it's not really a factory reset), it just erase data, than re-link with mavic 3, then when I try to charge it works, and when it was 90%, I upgrade, and it's fine, but i'm waiting for the new charging and praying. |
