DJI Wanda
Hello, there. Sorry for your inconvenience. The Airsense function is associated with many factors. You may check the following information below first.
1. The aircraft equipped with ADS-B function only receive the flight information sent from the manned airplane which installs the ADS-B emission module. For the airplane which did not install an ADS-B emission module or one which is installed the module but does not work properly, the ADS-B function can not receive their radio information and the news feed.
2. The other scenario would be, it requires radio frequency for the ADS-B receiver to get the flight information. Provided that there are obstructions, signal interference, or environment change, the system may not receive the information successively and thus can not warn you on App in time.
3. The aircraft can not source its effective information because of weather, environment, and other objective factors, which results in failing to send effective warning information.
4. Once disable ADS-B functions, your drone can not receive the radio message.
5. The signal sent by airplane is beyond the range of aircraft, too far to receive. |
