ExtraGloves
Flight distance : 19537 ft
Hey guys. Just curious about something. My Mini 2 has been hibernating for a little while. I know sometimes we get new firmware updates that end up causing problems and some of us downgrade etc. Months ago I updated to new firmware and my drone was all buggy. Downgraded back to 01.02.0300 and it was great. My android app is still version 1.4.8.
How has the latest firmware and app version been? Also is there any reason to not update the FlySafe Database?
But lastly the main reason for my post. I just got the Litchi app and I'm excited to use it but I believe it said upgrade to the latest firmware to use it. Is this true? Do you always have to use the current firmware to use the Litchi App? Also is there any reason to use Litchi if you're not specifically using the following features or guided paths? Like does it make anything else better (or worse) in regards to taking videos or pics and quality?
Basically, should I keep upgrading my firmware and fly the same app or just stick with what works?
Also, I assume using Litchi if something happens that wouldn't be covered by refresh? Will they be able to tell if you were using Litchi or the regular app? Basically, if I crash using the regular app but litchi has been used in the past will that void me?
Thanks!
